dude1116
I keep reading about pounding the pinch weld - where is the pinch weld located?
I actually just did mine. Make sure to paint it up real good when you're done.
I did the 827/948 springs ad also OME shocks. It's a 99% daily driver - but will beat the hell out of dirt roads, OBX SAND, and the occasional mud. Not afraid to take it about anywhere.
Stock 17" wheels (it's a Limited - *****).
What I wanted - and got was a much improved street ride.
The main thing is read all the information on here and ask questions on anything you aren't sure about. We'll gladly help as much as possible so that you can avoid the mistakes that some of us have made.:icon_lol:
That is my plan! I will also post pictures of before and after and I'll add my before and after ride/lift height numbers to the sticky.
So far it looks like I am going to go with one of the Tommudd Econo 3.5" lifts from JBA. Have to think which version to purchase.
I know I will need to get the bump stops. Since I will be dismantling the front end anyway, should I get new front lower control arm bushings where the clevis attaches and new front strut mounts?
Either one( OME or Ironman) are good, way better than stock
if Ironman get the 1/2 inch clevis, if OME get the 3/8s
Other than that which ever you choose
Check with Marlin on the strut fork bushings, he can help you out there if you need to replace ( not sure if I'm letting anything out too early or not ):emotions34:
I have also noticed that some members are using the front and rear coil spring isolators. I understand where they go, but I don't understand why you use them? Is it a noise issue, for lift, or some other reason?
Again, thanks to everyone helping me with my questions!![]()
Yeah, I'm going to post before and after pics. I will try to get pics of during.
I did see a post about the JBA UCAs where someone (I think tommudd) had shown pictures of the holes in the fender well where the arms attach. The member removed the material to allow the arms to articulate better. Does anyone have a link to that post? I have used the search function here, but it either finds no posts or hundreds of posts. I don't think I'm using the correct search terms.
That was what I was looking for, I thought it was a thread here on the forum. My bad!:Stupid Me:
Like Tom I DD my KJ with 3.75" of lift for years all over the country,handled better then stock and running 265/75R16's with 4.10 gears.
