Any thoughts please folk pondering a rear one on my 2002 3.7
Side note: i wouldn't dare put a weak d30 under a SFA KJ
No, I wouldn't recommended it for the casual wrencher....you need specialized tools and knowledge and someone who has done it looking over your shoulder...if you get it wrong, you can destroy your diff, locker, axle, etc...shop around...
The 'lunchbox' style locker (lockright, powertrax, spartan, aussie) is a much more forgiving install because you only replace the spider gears. It takes a few hours in the driveway without special tools. No more advanced than brakes or oil changes, IMO.
Good to know thanks are those lockers just as good i have a 2002 with the select a trac would it still be beneficial i thought 4wd part time is kind of similar to lockers
As good? Hmmm.... depends. Ultimately not as strong, but equally effective. You wont find a selectable lunchbox style though.
In Part Time mode the front and rear don't differentiate from each other - they are locked together in the transfer case. The diffs on each axle are still open so that the wheel with less traction will spin; Part Time doesn't change that.
With the SelecTrac, the transfer case acts as a differential between the front and rear axles so the Jeep can be driven on high-traction surfaces without driveline binding. In a turn the four wheels travel four different distances, which is why the SelecTrac has to differentiate between the front and rear axles - and then the diffs on each axle allow the wheel on the outside of the turn to travel faster.
FYI - 4LO functions the same as Part Time as far as locking the front and rear axles together except the gear ratio is much lower. But just like Part Time, the wheels with less traction still spin when in mud, sand, rocks, etc.
