jfortier777
Hot.
bohica-kj said:btw, did you order new lig nuts with those??
jeepjeepster said:fortier777, could you tell you had any decrease in performance with the wheels+tires?
jeepjeepster said:Why does it say: Wheel construction, 2 piece? Does the rim come apart?
jeepjeepster said:Can you use the stock lugs? I really do not want to spend more money on lugs.
jeepjeepster said:How far are you from eastern Ky jfortier777? We are planning a run in slade if you would like to come and its not to far. Sometime this month or next month.
jfortier777 said:THIS IS IMPORTANT TO LOOK AT! IMPROPERLY MATCHED TIRE/WHEEL COMBOS ARE NOT OKAY!
jeepjeepster said:Was that directed towards me? Every site Ive looked at says its ok to put a 255/70/16 or even a 245/70/16 on a 16x8 rim.
http://www.tirerack.com/tires/Spec.jsp?make=General&model=Grabber+AT+2&tirePageLocQty=
jeepjeepster said:jfortier777 said:THIS IS IMPORTANT TO LOOK AT! IMPROPERLY MATCHED TIRE/WHEEL COMBOS ARE NOT OKAY!
Eddo said:Actually, there is a little room in that chart. For example rubicon wheels are 16x8 and they are mount with 245/75R16 from the factory.
jfortier777 said:jeepjeepster said:Was that directed towards me? Every site Ive looked at says its ok to put a 255/70/16 or even a 245/70/16 on a 16x8 rim.
Not really, more of a general piece of information. Although I would not get those tires if I was you, I would get the 265s They will fit the rim better, and will give you a better tread life and better handling, you can probably get them for the same price as the 255s too, as long as you barter for it.
bohica-kj said:Any one know where I can get these rims cheaper : http://www.quadratec.com/products/92600_2XX_PG.htm
5 rims and 5 chrome center caps came to just over $350.00
looking at the: 5 on 5.5'' bolt pattern, the 16''x8'' size, and the 5'' back spacing. I'm pretty sure those will work on my Libby......Right???
dnm45227 said:Man looks like you got a pretty good deal. Hope they get broke in well on the trip.
