Kriszilla
That's a heck of a find. I paid a lot more for the one I had. It's also nice to see another AppRadio3 user on here!
Any help? I've read that it's a White/Green wire but I don't know where to look for it. I've got the power and video cable run from the rear license plate where the camera is. Now I just need to tap into a reverse wire so the camera comes on automatically when I shift into reverse. Where do I look for the wire to connect to? :mexsmoke:...I also need to find a reverse wire I can tap into to activate the backup camera. Anyone know where I'd find that baby?
Just as an update, I also went ahead and purchased one of the other mounting kits from eBay. You know, the one's that are still $134 on Amazon with the radio mounting to the faceplate? Well, you can get them on eBay now for about $34...
And it's a direct faceplate swap.
Using the radio mounts from the Metra kit, you can just put the other kit's faceplate. This is great, because it has a storage cubby that is identical to stock and even re-uses the rubber mat piece. It also has better mounting clips and utilizes the screw in the cubby area to tighten it down.
Do you have any pictures for comparison? Also who did you buy from on ebay?Just as an update, I also went ahead and purchased one of the other mounting kits from eBay. You know, the one's that are still $134 on Amazon with the radio mounting to the faceplate? Well, you can get them on eBay now for about $34...
