Mileage & upgrade concerns
The Jeep
Okc, Ok
My 02 is reaching the 180k mark and is my daily. I would like to start taking it on trail rides or just get to a good camping spot, nothing crazy. What should I concern myself with first, before looking into a lift?
Is it late in Liberty life to start slightly beating on it?
I wouldn't worry about it, if you've kept up on maintenance. Mine's at 160k and I'm not done wheeling it.
GunnerSchenck
I've got 205k and she still goes off road minimum of once/twice a month without a lift.
All in how you drive and maintain the old girl.
That being said, mine is 2wd so I don't have the luxury of creeping down trails.. she takes a beating :D but that just means I drive hard, not stupid.
And if something goes wrong, just make sure she gets fixed up right before giving her more hell..
You ask me, I'd say she just got broken in.
The Jeep
Okc, Ok
205k makes me even more optimistic. Lift is a debate I'm having because I need new shocks. Although I just read skid plates should be a first purchase.
GunnerSchenck
My shocks are pretty bad as well and not running skids either.. got an inch of sag whole way around so I've gotta watch wheel placement for ground clearance.
But surprisingly enough without the skids or lift, my two main problems I consistently run into are caking up the sides of my ******..and my main issue, I like to push her through mud/water thats too deep and flood out my engine bay. Even though youd expect it to be bottoming out, i rarely do. So I have a couple ignition coils and plugs I keep in my toolbox in the trunk at all times..
Other than that, know where your tires are at, at all times and you should be able to clear any decent trail and most of the crappy ones.
I will admit, being 2wd I run into some trails that make me go hell nah, but if I had 4wd I'd just keep on pushin.
It's not about how stuck you'll get, but rather how good you can get at getting unstuck.
All that being said, I'd get the skids first just to cut down on debris hitting the underbody and driveline. But you don't actually need a lift to off road, so long as you're not afraid to commit to the trail.
But everyone else is going to tell you the lift is a necessity for trailrides, but you stated nothing crazy and slightly beating on it.. so I assure you that so long as you know your liberty it will surprise you offroad.
Even got my girlfriend to admit that my jeep loves mud waaayyyy more than it likes pavement.
As for the is it too late in the libertys life for a lift? I'd say that's all in the amount of rust you have. Everything else is replaceable in a sense.
Been saving for 2 months for my lift in the spring and I'm sure I'll be probably around 215-220k and I'm still gunna be throwing money into a lift and tires. But that's because I got all my rust rid of/neutralized and por15'd the whole underside with a hammered finish rustoleum coating over it.
Only thing that bothers me is my rockers, but that's because they're half fiberglass from busting holes in them lol.. but gunna weld some new ones in come springtime. Only about 150 a piece for them, and I'm just gunna paint them black prior to install, grind back the weld zones, and touch them up after.
So, if you're not rusty, then I say heeellllllllll nah its not too late in the libertys life.
But I think that's just because my view on it is more...well if she dies, she'll be a perfect donor for the next KJ! :D
marko
MI
optimistc
I enjoy reading these reviews about milage and off road. are these jeeps capable of towing a trailer to do landscape work, say 1-3000 lbs, I plan on using a 10' trailer enclosed foe all of my tools/
GunnerSchenck
I can't personally speak on a long term note if you mean using it every day, but they pull plenty.. hauled my mustang the whole state with mine on a uhaul trailer.
And you can find plenty of experiences others have had pulling cars and trailer loads plenty of states distance
renegade 04
Albany New York
As long as you have the 2002 radiator with the in-radiator transmission cooler and also the factory transmission cooler your libby can tow a lot. I typically tow around 2,000 to 3,000 pound loads and have also have towed around 6,000 pounds no problem. The biggest problem with the libby is the fact that you can not put much tongue weight on it.
JasonJ
Michigan
Agreed. I towed a fully loaded 2001 Tahoe 4x4 with tow straps, 45 miles. The part that took the beating was not the transmission, or engine temp. It was the BRAKES. Rotors warped not too long after that (well, I'm sure they warped on that trip, I just didnt notice it badly until a week later).
renegade 04
Albany New York
The brakes do take a beating, but with good quality brake pads and rotors it should do fine. When I replace the brakes soon I will be upgrading. I am not sure what to upgrade too as in what brand and they type of pads and rotors I want.
