New lift, opinions please
Wulfhound
Escondido, CA
Thanks for the input, I will do some search to get up to date. I guess I want to here peoples opinions like yours. Thank you again for the info, will check jeepingbyal.com sir.
I aswell have the Mudd Eco lift 3.5" on my 2012 KK luv it especially with the new wheels & tires its a great lift and good price for what your gonna get.
Bmxer524
Lindenhurst, New York
Mine is a 2004 sport, it sits 17" in the front and 17 3/4 in the back. Thanks for the info I will search.
You definitely sagged alot. I know KJs sit about 19", I'm not sure of KK sadly. Anyways, I'll definitely get pics of my KK for you. I went with heavy duty OME springs and Bilstein shocks with 1/4" top plate, 3/8" clevis, and 2 extra rear isos per side. Idk how you feel about the rake or if you would rather get rid of it. Me personally I hate rakes and think very few vehicles should have one. The lift I chose actually leveled my KK out possibly even a little nose high(very slightly).
u2slow
BC
I went a different route lifting the KJ (see sig). My wife and I are happy with it.
Yes sitting where you are you need new springs and shocks for sure!!
I did one a year or so ago and he was at 17 inches as well, he went from 17 to 22.75 in a matter of 3 hours :roflsquared::roflsquared::roflsquared:
Said it had never rode as well as it did after the lift
Used the typical OME 927/948 springs and Bilstein shocks combo
Right now the tommudd econo lift is waiting for Ironman to get moved out west to their new warehouse and restocked Just found this out recently from jeepinbyal
Armysniper
Space Costs FL
Wow!!! 19" then I really need to get a lift asap. I personally don't like the rake so a front plate and coduit lock nuts is needed?
Armysniper
Space Costs FL
Thanks for the info dude!!! So when I put the lift I will be super happy if it gains 5" big differences between 17 and 22.50 or .75
Armysniper
Space Costs FL
Thanks buddy, you have one bad a$$ looking kk, love the aggressive look with wheels and tires. Enjoy it buddy nice rig!!!!!!!!
gsambray
thunder bay
I have an 07 liberty kj and want to lift aswell. The front is sagged so figure if im gonna replace front struts and springs might azwell lift it too. To help cut costs would it be bad to go with spacers in the rear since i just replaced rear springs with new stock onez and then get longer front struts and good springs? Never lifted a kj and heard nothing but bad news about ott lifts. I break enough stuff and dont want to do more work than neccessary. If i go 2.5 rear what front strut spring combo would be best. And should i run a different top plate or the stock work for me?.
TwoBobsKJ
Northern Ohio
Wow - a lot of questions, but here goes :rofl:
For the rear it depends on how high you are now. Measure from the center of the hub to the fender flare - you will need at least one extra upper spring isolator depending on how much the new springs brought the rear back up.
Front shocks (no struts on KJ's) are all the same length. New ones from Ironman are slightly longer than OME's and stock but not much. So, the added height comes from springs and any top plate spacer and clevis spacing/lift you add. Do NOT do an "OTT" lift - a simple 1/4" top plate is fine with the stock top plate.
Most folks around here run either OME or Ironman lifts with either OME, Bilstein or Ironman shocks for the front. If you lift it more than a couple of inches you'll need extended rear shocks (N132L OME's, the model for a 4X4 Dodge Dakota truck in the Bilsteins; Ironman does not yet offer an extended length rear shock.) The TomMudd EconoLift from JeepinByAl.com is quickly becoming a very popular lift. The FrankenLift from All J's is a popular lift kit as well.
Stay away from RRO unless you thrive on grief.
Keep asking questions!
