OBD scanner
ChiefRudy
Pittston, Pa
tcm code?
It may..
I found this on there site
Dodge/Chrysler/Jeep Testers : Linear Logic : Home of the ScanGauge
If i understand it correctly, the device can detect firmware ver of PCM and TCM for some testing there doing. So it looks like It can talk to the TCM.
I use my scangaugeII to monitor Transmission temps in real time. Not sure if that means it's talking directly to TCM or not.
I put an email into there support staff regarding the ability to pull/retrieving TCM codes.
So soon as I hear something back I'll post it on here.
ftaa
canada
It may..
that FANTATIC appreciated muchly
ChiefRudy
Pittston, Pa
Alrighty,
Here's the response I got from there Support.
"The ScanGauge will only read and clear trouble codes that cause the check engine light."
Now, I never had any tranmission issues so.. Does the KJ turn on a seperate indicator for transmission issues?
ftaa
canada
Alrighty,
no ... the tcm i inisde the pcm and will tell pcm to iluminate MIL light if there i a ****** issue you then ue the obd port to contact the tcm ... generaly ony expensive scanner will work
ftaa
canada
so i found a used solaris for 800 bucks this weekend and i bought it ... came updated to 2008 so thanks for the input guys!
John3seventeen
WV Panhandle
It may..
How are you getting it to report transmission temps? Can't find it on my Scanguage II for my 03
ChiefRudy
Pittston, Pa
I added an X Gauge in to read the trans temp. I used one of the codes on this page if I remember correctly.
Dodge Specific : Linear Logic : Home of the ScanGauge
Now.. My 06 KJ has a CAN computer system. Your 03 might not. My fathers 05 KJ doesn't have a CAN system b/c the code for trans temp doesn't work on his and the code I inputted is ment for a CAN system.
To find out the system your KJ is using at the main menu of the Scangauge select MORE > MORE > MODE
This link here will have all the available codes on there site. However, by the looks of it. Only the Dodge-Specific page has a code for trans temp and like I said, that is CAN only.
X-Gauge Commands : Linear Logic - Home of the ScanGauge
Now you can always google search for a code and see if someone made a custom code that works.
Hope this helps.
JasonJ
Michigan
I just bought an Innova 3160, $180 on Amazon. I got that one so I could do airbag codes on my Acadia.. but I connected it to my 03 KJ and I see ECM and TCM data, including some live data from the Liberty. I have 24 live data feeds it reads. Over 40 on my 08 Acadia. Including trans temp.
No doubt the Solaris is a nice scanner.. but it seems overkill.
Any innova products or other entry level scanners that can cycle the ABS solenoid?
ftaa
canada
i didnt want to spend the money but this one came up for 800 bucs its a 4000 doar scanner and it does the quic earns for the ****** ... its shop grade and i got a HUGE bargain.... now i can charge 30 bucs to the ocal guys ionstead of going to the steaer ship for 150 bucs.
which solus did you end up getting? I see a couple on ebay for 400-600 bucks.
Any advise on what to look out for?
Thanks
ftaa
canada
I really dont now .. i just got this one.... alot of them are broen .. or not updated .... mine was updated to 2008 and does everything i need. sorry im not much help about it yet.. gimme a wee or 2 and i'll be a master
one of the other guys should now better.
ftaa
canada
***.ebay.ca/itm/Snap-On-SOLUS-EESC310-DIAGNOSTIC-SCANNER-w-17-KEYS-SOFTWARE-OBD-II-Adaptor-/151580598097?pt=Motors_Automotive_Tools&hash=item234ae85f51 same one i got.
