badaxewags
has anyone out there installed off road lights directly to the bumper. will the install hold up?
Here are mine. custom made bar thru the bumper facia.
I have Hella 500s 3M taped to my bumper.
I took the U brackets off the lights and removed the bolt. I then welded the brackets to the biggest washer I could find at Lowes. I painted them with a color from Dupli-Color as close as I could find to my Jeep. I then put the brackets back on the lights and covered the bottom of the washer with 3M two sided tape. After that, I measured where I wanted them, made a template out of wood (to make sure they were pointed straight forward) and then stuck them on. I then used a level and the wood template (to keep them pointing straight) to get them aimed right, up and down. Then, thightened the light the rest of the way. Which turns out to be a PITA to do that and not move the lights at the same time, but with some patience, I pulled it off.
They are aimed very well and do not vibrate anywhere near what I thought they might. You have to hit a good bump in order for them to shake a just a little. The set-up has held up really well so far.
I had a bar made for the front of mine.
I love the way this looks on yours, and would love to do it to mine. Only issue is the dratically different '07 bumper. What I am considering is building a similar bar, but then having it mounted to the steel bumper (pull the cover off) and then cut a "U" for each tube out of the plastic fascia so it can be slid back over the mounting plates/steel bumper. You'd just see each steel tube coming up out of the plastic fascia. I'd put it as close to the grille as possible so you don't see the missing plastic on the rear. I think that could work out decently well.
In some ways I wish I did something like that, now it's a PITA to take off the grill & bumper cover to do other things to it, I have to remove the light bar & lights first. I've been thinking of pulling it and 're-desining' the way I mount it, Hind sight I guess!
Can't wait to see yours when you get it done.
why not move it foward? when I did mine I moved it forward and since my cuts werent very good I went ahead and grinded down the bottom so that it leaned forward like a stinger, that way it looks good and will protect my grill
