BjBnet
When I leave in the morning the oil light is on unless I shut off the jeep, wait a couple seconds then crank it again, then it goes away. bad or going sensor?
thanks
thanks
I would check and replace the oil pressure sending unit, right above the oil filter, and change oil and filter while your at it as well just to be safe. Don't want to budketize your engine!
yea but it's only on my first start or if she's been sitting for a few hours..
Be careful with that bud. No oil getting to an engine is as you know very bad.
I just did an oil change. After I started it back up again the engine didn't sound to good and vibrated really bad for about 2 seconds because it was starved for oil. If it were to do that for a couple minutes. Yikes!!!
You don't want your engine to go without oil for too long. Def get in touch with Jeep Technicians.
I thought some of you guys could use this. HOW-TO oil pressure switch
http://www.ehow.com/how_5876296_replace-pressure-switch-jeep-liberty.html
thanks
I'd love to stick a mechanical Oil Pressure gauge in the dash, or even just under the hood for peace of mind. Anybody make gauge pods for the A-pillar or a pod that mounts on the dash?
No KJs have an oil pressure gage.
