So this is an '04 Jeep Liberty I'm looking at buying used. I don't have a whole lot of money to put down, but the used car dealer swears the engine is reliable/well maintained, and it has *relatively* low mileage (around 75K).
I just need a vehicle to get to work.
Now, here's the issue. Although it may not be immediately visible (see first pic), when you get down around the undercarriage you can clearly see it was in at least a small fender-bender of some kind where the bottom of the driverside door is.
It doesn't seem a big concern to me, but the rust I don't like at all. Its down around the edge of the undercarriage on both sides- kinda hard to tell from the substandard photos I grabbed at the lot. But on one side, the bottom edge is rusted and even a small section of it missing underneath. On the other, the lower right corner of the door is rusted and missing.
#1, the car
#2, lower right corner of driver side
#3, underneath lower right corner of driver side
#4, lower left corner of passenger door (a bit cut off, but you can see the corner is rusted and partially missing). The area is smaller than it appears in the photo
Anyway, I'm wondering if I do get this car, just how hard and expensive it would be to fix these rust issues.
Also what I was wanting to know is..... does the Jeep Liberty have any kind of accessory you can buy, that would be say a plastic bottom skirt trim, maybe black or other, that you could get to cover up that bottom edge? Does that make sense.
Sort of an undercarriage bra of sorts.
It seems such a thing would sell, as many cars do rust around these areas.
#1, the car
