Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
ok look and look but not sure if i got the right answer. can i put OME front springs on with a 3/8 spacer on top of the strut and a 1/4 spacer blow the strut. or will it be to much lift?
It would work if you mean a top plate of 3/8 and a 3 ring clevis, ( 3 conduit nuts = 3/8 of an inch)
total would give you an inch and a half of lift
whoops you said 1/4 on the bottom so sure either way
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
