huntbuggy
Huntbuggy's lift - step 2
Got rear shocks and springs in without too many hassles when time permitted on Sunday. Put in bumpstop pucks but waiting on a wheel stud for each side before the rear tires can go back on ... will have to ensure the drums/shoes are a-okay too on reinstall. (Reading up on drum basics JIK, don't want burning rear brakes driving to alignment)
Pulled the airbox, battery and tray and moved the cruise control and relay harness aside yesterday - then cleaned up in there bigtime and loosened the shock mount bolts a tiny bit to ensure nothing was going to be a problem.
Passenger side got started, the clevis pinch and lower bolt were a ***** but coaxed out, sway bar link came off easy. Couldn't get the UCA balljoint to knuckle bolt to budge at all... still PB Blasting and looking for a monster 21mm wrench. Went ahead and pulled the spring/shock assembly and with a little sweat and a tiny bottle jack against the LCA it came out.
Driver's side tonight was a fail. Same as the other side, the UCA joint bolt is really stuck - more PB... The sway link was jammed onto the bolt and needed heat and serious hammering to come free. The clevis pinch bolt came out after impact, only needed breaker on the other side. The lower clevis to LCA bolt spun and the nut is really fused... more PB. Spent the rest of the evening cleaning up parts and organizing tools for next round.
Each bolt is a battle on this thing. Every evening a new knuckle-busting job to come home to. Could've spent to install but am learning some and getting very intimate with my Libby at least. :love51:
