You can never go wrong the the Odyssey PC1500DT,and they last.
Retired my original PC1500DT awhile back,still use it at work to power my smoke machine and have not charged it in about a year and tested it,still said good battery(but low charge) with 560 some CCA's out of the 850cca rated and that battery was built in July of 2007.
I now run a Odyssey PC1750(group 65 battery) in my KJ with a battery tray from SasquatchParts.com which is 950cca rated,last test it was showing 1330cca's.
What part number did you go with? Can you please directly link it?
I have a 2002 KJ Limited and I’m looking to install the PC1750 battery as well.
I’m also considering upgrading the alternator and wiring.
My current diehard gold battery is about 5 or so years old and it dies if I don’t use the car every 10 days or so.
I currently have a 750W amp for my sub and a capacitor, I’m about to upgrade to two amps, one 4 channel 400W and a 1,000W for my subs.
I also just changed all my lights except instrumentation lighting to LEDs so hopefully that helps take some load off.
You guys think the stock alternator should be able to handle this new setup?
I’m strongly considering ditching the capacitor, since most of what I’m reading says it does more harm then good.
Thanks!
