bluerolo
Thx guys for help on the last code I had, O2 sensor that would not go away until I threw out the new Bosch sensor I had installed and installed a new factory sensor. That code is gone but now another...
1. first code was for bank 1 upstream sensor, at that time I had no codes for bank 2....but in the process of confirming that the bosch sensor was bad I removed the factory sensor from bank 2 and placed in bank 1.
2. After confirmation I moved the good factory sensor back from bank 1 to bank 2...and now all of a sudden I'm throwing a P0430 code in bank 2....also a p2098 came up but then went away.
3. I think it is too coincidental that I remove the factory upstream from bank two, then put it back and then immediately after have a cat fail...
4. I did check for exhaust leaks by blowing air into exhaust pipe while spraying soapy water around cat and O2 sensors...no leaks....any ideas?
