P0501 on 2005 liberty
Tarkhan
Hello, My liberty shows check engine with P0501 code, the speedometer and the odometer aren't working. I know it's related to a sensor but I can't define which sensor exactly. Anyone can help?
Start with the wiring that goes from the sensor in the rear diff up to the body
9 times out of 10 the wiring is broke near body
Tarkhan
Thank you
So it's related to the rear diff sensor and its wiring right? it's not a transmission sensors problem, is it?
No it's not a trans sensor problem.
Follow the speed sensor wiring from top of rear diff upwards looking for broken wire..
Tarkhan
Check the speed sensor wiring top of rear diff/ connection.
Thank you so much. I will check this and see if it solves the problem.
I just added an edit to it..to follow the wire..^^ see post 4 again.
Billwill
White River, South Africa
Check the connector on that Diff Sensor is on firmly.
I had a bad connection there...after fixing it the speedo worked fine but the CEL stayed ON until it cleared itself after driving for a week or two!;)
Do not know what year your KJ is but all 2005 KJs have a TSB that the wrong diff oil was used at time of assembly that chewed up this sensor. Fix was to drain diff oil, clean out diff, replace diff sensor, fill diff with correct oil!
Tarkhan
Awesome, will check. thank you
Tarkhan
It was the sensor, I've checked the cable and it was fine so I changed the sensor and it worked. Thank you so much guys!
Billwill
Maybe time to drain, clean and re-fill the rear diff if you do not know when this was last done although you would expect this oil to have been replaced since the Jeep was built in 2005!;)
Tarkhan
That's what I was thinking of I will do next weekend
