P2181-Cooling System Performance
oboudreaux
2007 KJ LTD getting a P2181 code.
ECT is reporting a constant 21C. Checked the resistance at ambient and it's 9.9k which seems right or wrong depending on where I look.
Anyone have a resistance chart for the ECT Sensor? If it's in spec I assume the thermostat is my next stop?
Thanks!
ikuo78
Japan
I don't know the specified value, but if you put it in 90℃ hot water and the resistance is the same, it's broken.
I think it will drop to about 0.5KΩ or less at 90℃.
I forget if the gauge and ECU use the same sensor.
Is the gauge also low?
I think it's unlikely since it's summer.
If you can touch the pressure tank or radiator after driving, the coolant temperature is really low.
Suspect the thermostat.
oboudreaux
Yeah, the gauge isn't budging. I pulled the sensor and it seems fine.
Replaced the t-stat. It's warming up now but it takes its sweet time.
Thanks for the help!
