- Joined
- May 31, 2020
- Messages
- 60
- Reaction score
- 23
Shorter post than the axle swap, but still a bit of information to be processed. It’s been stated several times that the 4.7 is the 3.7 with an extra pair of cylinders. And that it uses the same motor mount location.
So it should be a straightforward swap right? Get a 4.7 from a 2012 Ram and drop it in along with the engine harness and ECM. My roadblock comes from programming and mating. There was a programmer for the 2008-2010 KK, but the 2011/2012 got a different encryption. HP tuners claims compatibility, but have yet to read about anyone who has used them.
How complicated would it be to adapt the 4.7 ECM to the KK PCM. As well would the 545RFE be necessary to swap over as well since that is what was mated to the 4.7.
The transmission swap gets a bit more complicated due to the different control inputs if I’m not wrong; electronic vs oil pressure. If I were to do the swap, I would already be putting in a new transmission built by either ATS Diesel or from someone who sells remanufactured 42RLE’s.
Short List:
Get 2012 RAM PCM and send it to a programmer who would flash it the KK, if they could even do it.
Cut louvers into the hood for heat dissipation
Larger capacity radiator Clutch Fan will have to be removed Custom exhaust
Short List:
