rockymountain
First off, I'd like it to be known that I use Amsoil so I do not change oil as often as normal. It has been cold where I live and it came time to change the oil in my '04 with 15K miles. When I took of the filler cap I noticed a lot of foamy stuff. My first thought... pcv valve. I took the valve out after cleaning up the foam and noticed that it was probably stuck and really gummy. I didn't mess around with it and just picked up a new one. To be safe I took the whole ventilation tube off and let all the water that was in it drain out. I also blew it out with compressed air. Anyway I guess my question is that does everyone have trouble with the factory PCV valve? I also ran into the same problem with my 03 in which I replaced the valve and never saw the problem again. If anyone is bored, go check and see if you have the same thing. Just curious I guess. Thanks.
