PCV valve replacement
Leeann
Maryland
I had to look at my new one a couple times to be able to get the original one out in one piece. It is a bit funky.
Luke
Interloper
Bancroft, Canada
Its part of my yearly maintenance too ... it's to cheap to not replace it.
I had that yellow gunk (condensation) at the (oil) filler when I first got her... not any more. :shrug:
dude1116
Pompton Plains, NJ
Eh yeah might as well give it a shot. Was just wondering what would happen if I didn't. Cause nothing has happened thus far in 50k miles.
ron.dittmer
Dundee, IL
I own a 2006 Liberty 4x4 3.7L gaser. I looked for my pvc valve and think it is attached to the oil fill tube. Am I right about that? I can't get it off because of a hard plastic retainer that doesn't cooperate.
What's the trick to getting the old pvc valve out? This assuming I have itentified it correctly.
The engine has 55k and I don't know if the pvc is original given we bought the vehicle used. Regardless, the foam block in the air filter compartment was quite oily & very dirty where exposed to the tube so I suspect my pvc needs replacing.
Luke
Interloper
Bancroft, Canada
Yes that's it ...look at your new one ...you'll see how it locks in. I believe it's.. push in and rotate counter clockwise. It's been a while though.
TheSauce05
Kentucky
Just replaced the PCV valve and oil filler cap for the first time the other day on my wifes '02. 120,000 miles and never been replaced. Still loose and rattling with no gunk in it, so that's good. Replaced the oil filler cap because the rubber seal was missing so the cap was pretty much just sitting there. Now I've just got to get the exhaust leak fixed and it will be 100% mechanically. A little body work and some minor electrical and the entire thing will be 100%.
Leeann
Maryland
The whole hard plastic thing is the PCV valve. Remove the hose, push the old valve in and rotate away from you then pull out. New one installs the reverse of the old.
ron.dittmer
Dundee, IL
I got the PCV valve out per your instruction. I didn't have a new one on-hand. The old one rattled but seemed a tad gooey inside from dirty oil so I soaked and flushed it in kerosene and it rattles like new so I put it back in. Next time I'm at an auto parts store, I'll buy a new PCV and get it in there.
Thank you all for the help.
Truly amazing how many won't change out a very low cost part like a PCV valve to keep their vehicle running better, but will spend 100s and thousands on a worthless sound system.
Testing them to see if they rattle doesn't always work, they still maybe sticking at times.
dude1116
Pompton Plains, NJ
Not to knock you or your knowledge, but truly amazing how I've never seen an answer as to how it affects performance or engine reliability. Personally, I will be changing it soon. But I still would like to know...
Simple answer
Its part of the system in which the engine breathes
gasses from within the engine have to get out somehow. Used to be you just had a breather on the valve cover to vent gasses
If the engine doesn't vent then it has to go out another way which is not good. Again cheap insurance for a healthy engine
ron.dittmer
Dundee, IL
I won't take offense to Tom's comment here as I am not sure he meant it for my previous reply. At age 55, I am not into sound systems anyway.
I do plan to replace the PCV valve soon, the next time I pass by an Autozone. I just don't feel it to be critical to be done immediately, especially since I cleaned it well with kerosene.
