It's no big deal until you need to get your Jeep inspected. Check the hoses that go into your evap canister, I'd bet one of the cheap plastic hose clamps has gotten brittle and broken. I replaced mine with metal ones. Also check for rotted/torn hoses and replace as necessary with the same-size vacuum hose. Should clear it right up.
It's a big deal if you leave that MIL on,then you will not know when/if a new problem has come up until it's to late.It's no big deal until you need to get your Jeep inspected..
The biggest offender to the P0442 code I have found is either cracked hoses on the vapor canistor,the real oddball little one that has a 1/2" end and 3/8" end.The other big one is a failed natural vacuum leak detection pump.
