protek yer neck
now the sweet stuff
the sawsall came out today, I only did the front, following the exo. I gota draw some pics for the rear, you know its gota look good
I'm making coil mounts on the lower control arm, so I don't have to move the coil bucket forward. There's enuf crap up there as it is,
I'm stuck right now I need to move the track bar mount forward, but it lines up directly with the steering box, if I weld the track bar mount to the frame it'll make changing the steering box a pain, and if I bolt it, the bolts will be right into the side of the box. Maybe I will buy a orbital valve and be done with it.
As for lockers don't know yet, probably run open for a little, probably weld the rear, my boss has some gears for me 5.86's but I don't know if they'll be to harsh for the doubler
