Rare find
jlh571
My father in law owned this 06 liberty crd diesel. Doesn't run. I worked on it but he doesn't drive so time to move it. Been garage, beautiful and no damage. 100834 miles, new timing belt, lift pump, fuel filter, hpfip. No pressure in fuel rail. Might be programming in the computer? Has small hole in radiator from removing the fan. Asking $2995. Or ?
DadOSix
Cumberland, MD.
Might help to know where the CRD is located.
BigMopar440
Pueblo, Co
Can you get more pics of the exterior and interior? What was the mileage when the timing belt was done? You have receipts for that? What lift pump mod did you do? In tank or inline? Why do you think it is a computer problem and not a failed I.P.?
Thanks.
jlh571
It's almost dark here. I can upload more pics tomorrow and anything specific you want to see. The timing belt was done since I had to take it off to get to the hpfp. As well as the lift pump that is in the tank. All done at 100834. My wife has a relative that owns a diesel shop and he said he'd have the computer read, it may need reprogrammed. Unfortunately he doesn't live close to look at it.
jlh571
He are some inside pics. I did also replace the fps, and when I read the codes there are not any now. If I unplug say the fps it instantly trips a code. It very well might be a bad IP. Low chances but it does happen. It is a rebuilt.
So it's not making rail pressure on cranking? Are you getting any pressure at all?
