Rear bump stops
vlad588
Vancouver
I’ve installed OME Lift springs 2948 in the rear with N132L shocks and two hockey pucks for bumps. But now the distance from lower bump stops to upper one is just over an inch, so anytime a load is put in the trunk the two bump stops come in contact. Basically i only have just over an inch of upward travel. That doesn’t seems right to me. So i wanted to see what everyone else space between bump stops looks like.
How much lift did you get? If you have 2 inches of hockey puck, with 2 inches of lift, the squish distance should be the same as before.
vlad588
Vancouver
I can’t remember the stock ride height, I believe it was 19” and I’m currently sitting at 21.5” so 2.5” of lift. Unfortunately I don’t remember the squish distance i had when it was stock but it would seem it should be bigger then an inch.
duderz7
Weiser, ID
I wonder if your upper bump stops are extra long? Also, looks like that tag in the spring doesn't say 2948, are you sure you got the right springs?
vlad588
Vancouver
Thats just a wrong side of the tag, it says 2948 on the other side. I don’t imagine upper bump stop being extra long as i got it as a direct replacement, but i guess anything is possible. I’m really wondering if I should just take out one of the pucks from the bottom or am I risking blowing the shocks.
turblediesel
memberable
Alaska
Years ago I put a rancho springs and shocks lift on my CJ-7 and didn't know the bumpstops needed to be raised. Noticed the lower shock mount was dangling from the shock. The welds to the differential had broken. It didn't have bad rust or welds. It just bottomed out hard leaving the airport after picking up a girlfriend and a LOT of luggage. Everything fit inside the CJ-7 cube but she had to shift because luggage blocked me from the shift lever.
I haven't lifted my KJ... yet, but maybe switching to a round-topped carriage bolt would gain a little travel. Cutting a bevel around the hole on the bottom of the upper bumpstop might give the same clearance.
klc
“It flies like a truck.”
PNW
Here’s the left rear on mine.
vlad588
Vancouver
Thanks for this picture, looking at your upper bump stop it makes me think i do have a longer one. It looks like i have 3 “coils” sticking out where you have two.
klc
PNW
So far as I know it’s original stock. It’s what came with the Jeep when I bought it two years ago.
Bobsearle
I can’t find the Tereflex bump stops on their websites. Are there any other options for longer front bump stops?
Apparently they aren’t offered on the website but they do exist and are available if you give Tereflex a call.
KingKJ
The Rock Spotter
Utah
Does anyone have part numbers for any rear 2 inch extended bump stops?
KingKJ
The Rock Spotter
Utah
ok, hocky pucks it is lol, should be interesting, maybe i'll color match the the new upper bump stops for some reason amazon only sells bright orange ones lol, I lost them after hitting a puddle too hard and haven't had any bump stops for the past 6 months.
