Rear coil spring installation
WesChapman
N Idaho
Is it possible to install the rear coil springs the wrong way? If so, what is the correct orientation? I think I put one in upside down if that is possible.
WesChapman
N Idaho
What brand? The smaller loop goes on top with OEM and OME.
hahaha, sorry I forgot only my wife can read my mind....
I installed OME 927's. I'm pretty sure I put one in upside down. I was hot and frazzled the day I did the rears.
rockymountain
Spencerville, IN
927s are for Front. do you mean 948s? Anyway, if OME then the end with the smaller loop goes on top. The small loop fits right around the bumpstop.
WesChapman
N Idaho
Yeah, 948's. Memory isn't what it used to be. Thanks, I'll be flipping the passenger side this weekend.
WesChapman
N Idaho
OK, I'm not an idiot, I installed the springs correctly.
Are the OME 948's supposed to be really bouncy?
WesChapman
N Idaho
Brand new Bilsteins at the same time as the spring change. Only about 3000 miles them.
