rear coil spring removal
Well thanks but that didnt tell me anything I don't already know. I needed to know where to jack and where not to jack to remove springs. I rested the body on stands and jacked up opposite side compressing spring while using bottle jack on the side I was removing and worked like a charm.
Well excuse me..............:icon_lol:
But only time a "bottle jack" maybe needed is when I do 4 "plus inch" lifts
normal 3-4 just pry down on one side, compress the spring as I'm shoving it up in with my hands
Like I said very easy :shrug:
mx3_ryder
troy VT
Pucks are one inch thick each so 2.25 or 2.5 inch bolt is long enough for two
washer on top and bottom , I use 1/4 or 3/8 inch bolts on most everyones
I use regular bolts due to if you ever need to remove them carriage bolts can be a huge PITA
Nothing against what Bob just quoted but from experience
used to use carriage bolts but switched over:icon_lol:
2 1/2 inch bolts are not long enough for two pucks not even without washers. You need 3 inch bolts when adding 2 bumpstops on an 02, not sure if other years will accept a shorter bolt or not.
?? Installed on 02s-03s-04s etc they all worked for me
mx3_ryder
troy VT
I believe ya since you've done so many. I took your word and never measured the pucks I got from my local Ace hardware so they must be bigger than inch thick.
They sell hockey pucks at Ace Hardware ??
Wow we have to go to a place that sells sporting goods etc and then sometimes they do not have them. May have to check Ace out then and see if they do
krisP
NY/PA
would using apoxy to attach them be a bad idea ?
Ya on the bolts!
I used stainless bolts, drilled 1/4" hole though the used played pucks.
Left enough bolt room to go through the center drilled spring perch ..easy.
54734[/ATTACH]"]
Years later they are still there ! :gr_grin:
mx3_ryder
troy VT
Measured my pucks and are exactly 1 inch. Not sure why 2.5 inch bolts wouldn't work for me with not even the littlest thread showing under perch.
Must have very short bolts in your part of the world :icon_lol:
mx3_ryder
troy VT
Figured I would just post this here. My cv's are clicking now after installing lift but were fine before. What now?
4x4kayak2112
tx
Now your at a different angle......replace them, they were getting bad before the lift.
Sent from my SM-N900P using Tapatalk
mx3_ryder
troy VT
Only noticeable in 4x4. Just rebuilt the transfer case end of intermidate shaft could it possible be the opposite end or still the cv's.
Rebuilt the front drive shaft ?
Intermediate shaft or what 99% of us call it is in the front diff on the right side
and CVs are bad more than likely plus possibly the intermediate shaft in the front diff
Also check your rear ujoints
mx3_ryder
troy VT
Yes, I meant front drive shaft not intermediate shaft. Front drivers side cv axle is badly shot, slinging grease and making a ton of noise as discovered on lift yesterday. Just picked up a new Napa lifetime warranty replacement.
Kal-El
Glendale, Arizona
Just curious..I kinda like the idea of having pucks in my suspension, but will they benefit me at all if I'm just replacing my old stock springs with basic Moogs?
