Rear Differential
sunvale
michigan
I have been hearing a howl from the rear for some time. Its a 06 CRD, my second one and both had the same noise during various speeds. Does the Diesel have more torque and the Differential is for the gas version?
Peter
turblediesel
memberable
Alaska
The only differential difference between diesel and petrol Liberties is the ratio. Howling is probably wheel bearings, pinion bearings, or lack of gear lube.
You're right that the diesel has more torque. The torque converter is the typical fail point for the CRD's extra torque.
On mine the pinion bearings were shot, howled at around 50mph under acceleration, silent on overrun.
The Diesel manual and auto have different ratio diffs.
u2slow
BC
I've done pinion bearings twice now in the KJ. Once with 3.54 and once with 3.73. First time it sounded like a howl. 2nd time was a weird swishy noise (thought it was the tcase.) Seems to be a common thing.
The dodge 8.25" was used in half-ton pickups and cars with small V8's so it should be up for the task.
