Rear end ratio
BroBird
Kansas
I have an 06 Liberty, the rear end is making noise. I was told the spider gears are bad. My question is, how do I determine what my current rear end differential gear ratio is?
3.7 V 6
2006
all stock
VIN: 1J4GL58K06W179682
BroBird
Kansas
Big Al
Let's get Cracken
Vancouver,B.C.
I've opened up my 8.25 rear end a month ago to change the oil and my spider gears are all chewed up.
Gear oil and magnet was a mess.
I've also have the loud gear train noise that you have.
I've also have the extra option of a limited slip rear end. AKA posi traction.
Not sure if the spider gears are the same for a limited slip with clutch plates.
When I do decide to change them, I'm going to contact these guys.
They may be able to give you more info on what you need.
https://www.yukongear.com/difflist....385&ModelName=Liberty&Side=Rear&DriveType=4WD
