rear lower control arms the same on 04-07 as 02
jeepguy4276
Fargo North Dakota
Are the rear lower control arms the same on the 02 as they are on the 04-07? I found a good deal on some mopars but it lists them as being for 04-07. They do look different then mine. I thought all of them were the same though.
Cardhu
Great White North
They changed the style over the years, my 07's were smaller than the recalled replacements
Above are the original
Both are same length
They started with a larger boxier style then switched to the small square tube style later . Then when they did the big recall in some areas went back to the original larger style
krisP
NY/PA
the smaller style tends to get rust around the weld for the rear sway bar mount
Mine are original smaller style I assume.
60026[/ATTACH]"]
What does the larger ones look like then?
