removal of transmission in a day, is it possible?
KingKJ
The Rock Spotter
Utah
so i'm going to be attempting to remove my transmission out of my jeep liberty in the span of about 1 and 1/2 daysish, Any tips on how to get this done such as shortcuts I can take? If I have to I can do it over more time, but I'd prefer to get it out as quickly as possible. I'm not replacing, only removing.
CheddarGau
Lower Mainland BC
Usually the service info is good. In many cases not taking short cuts greatly speeds up the job. Pull the transfer case off first in order to make transmission removal easier. I would be gentle with the connectors. Push in connector release lock tab and then remove the connector.
KingKJ
The Rock Spotter
Utah
well I'm not caring about keeping anything in good condition except for the transmission itself, everything else is pretty much useless, I've already identified that I can just cut the exhaust pipes out of the way and cut the wires to the o2 sensors instead of unplugging/unbolting. I've also been unsuccessful in finding a ton of info on how to do this so I'm trying to get any advice I can find, This vehicle is never going to have a transmission again, so that's the only reason why I'm even attempting this.
CheddarGau
Lower Mainland BC
Cut everything that's in your way in that case. Unbolt starter, remove ring gear bolts, remove trans mount and remove bell housing bolts and pull it out.
u2slow
BC
Had the trans out within a day a few times. Usually takes longer to put it all back together.
Thats working on a driveway or concrete floor... blocking, axle stands, jack, and a creeper sort of operation.
CheddarGau
Lower Mainland BC
Typed in "jeep liberty transmission removal" and this is the first thing that pops up.
u2slow
BC
Definitely drain the transmission first. (Remove pan). Drain torque converter too, if possible. Otherwise you have a 95% chance of an ATF lake on the ground.
KingKJ
The Rock Spotter
Utah
do you know how to drain the torque converter?
u2slow
BC
Some torque converters have a 1/8" npt plug around the edge somewhere. I don't know about the KJ.
burntkat
You can't remove the ring gear bolts without removing the clutch or torque converter first. Ring gear removal isn't required to remove the transmission.
burntkat
It isn't possible before removing it. Very few TqCons have a drain anymore. Just accept that it's GOING to make a mess and plan accordingly. Ie, lots of cardboard and kitty litter.
Once you have the TC bolts out and are ready to split the engine and ******, put a ratchet strap around the face of the TC to prevent it falling off and making a mess.
CheddarGau
Lower Mainland BC
Pushing torque converter towards the transmission once separated will keep it from leaking. Assuming you don't tip transmission forward and have it slide out.
