Replacing Flasher Relay, Where is it??
adKyaK08
Saranac Lake, NY
I recently upgraded all of my bulbs to LED. Now since they require less power than the older ones, they blink twice as fast. I bought an LED flasher relay and figured it would be an easy fix, but i can't find it anywhere...any ideas as to what i have to take apart to get to this? all suggestions would be greatly appreciated!
adKyaK08
Your out of luck,the flasher is part of the harzard light switch located in the center of the dash.It's a intergrated part of that switch and can not be taken apart to replace just that flasher relay.
You need to put load resistors on each LED bulb you put in for the turn signals.
hyde
Thanks TJ, I was just thinking about this, and was hoping that I could get rid of the clicker, but no luck... :) Nothing is that easy with a Jeep, now is it..
