Required Fluid Types
Billwill
White River, South Africa
I have been using Dot 3 Brake Fluid for the brakes and Clutch Reservoir since 2002 when I picked up my Export CRD.
This Dot 3 is becoming very scarce...can I safely add Dot 4 to the brakes and clutch reservoirs?o_O
turblediesel
memberable
Alaska
Someone found a sticker on the axle tube viewed from the back on the left side. Check the build sheet with your VIN#. Find a sandy gravel road and do a little burnout with someone watching both back tires to see if they both throw dirt at the same time. It takes a little spin on one side before it engages... or it's broken or doesn't have it.
Type your VIN number in here for the build sheet. https://fcacommunity.force.com/RAM/s/equipment-listing
Trac-Loc had a sticker on the left side of rear diff, but stickers often are long gone.
If I remember right only 02, 03 & 04' & some 05's were possibly equipped with them as an option.
They were a clutch based locker, also knows as trash loc. My 04's clutch packs were replaced under warranty @ 33K miles.
The Trac-loc required a 4 oz bottle of mopar limited slip additive to gear lube.
Another way to tell: With both rear wheels off the ground, an open diff, when you turn on wheel will have the other tire spin in opposite direction.
Track Loc both tires spin is same direction.
I have an 06 6spd, my rear wheels spin opposite directions when manually done
Artimus
Houston,TX
I told my High school buddy whose a mechanic about replacing the transmission oil on my 2007 Jeep KJ, and since I haven't changed the transmission oil since I got the KJ in 2016, he advised not to do it now. His reasoning was that if I replace it with new oil, the transmission won't get into gears because the new oil's viscosity will be too thin compared to the old oil and won't shift properly.
Starting mileage in 2016 around 162,000 and now has 180,767, thats 5-6 years and 18,767 miles later.
Anyone heard of this before?
Assuming it's an automatic, you don't want to flush it out. Just drain, change filter and refill.
duderz7
Weiser, ID
Drain and fill is fine, it's the flush that kills it. If a drain fill causes issues it was nearly dead anyhow and at least now you're close to home, but this is highly unlikely. Unless of course you're already having issues?
Robert4455
This is for the 3.7l engine
ENGINE OIL: 5W-30 (5qts)
ENGINE OIL FILTER: Any filter that works for the 3.7l works fine
(change every 5,000-7,500 miles)
TRANSMISSION (Auto): ATF+4
42RLE (2003+) 4.1qts
45RFE (2002) 5qts
T-CASE: ATF+4
NV242: 3.4 pints
NV231: 3 pints
FRONT DIFFERENTIAL: 80W-90, 75W-90, 75W-140
(change every 12,000-15,000 miles)
(2.6 pints)
REAR DIFFERENTIAL: 80W-90, 75W-90, 75W-140
(4.3 pints)
POWER STEERING: ATF+4
BREAK FLUID: DOT-3
(fill to the level)
ENGINE COOLANT: HOAT (14 quarts)
what ever else i am missing add it, i think it would be nice to make it a sticky if someone wants to take the time to make one, and if i am totally overlooking it, then just point me to where it is and i will ask a mod to delete this post :)
http://www.amsoil.com/guides.aspx
http://www.amsoil.com/mygarage/vehiclelookup.aspx
What about A/C refrigerant and Pag Oils?
hvacmrm
45RFE (2002) 5qts
T-CASE: ATF+4
NV242: 3.4 pints
NV231: 3 pints
(2.6 pints)
(4.3 pints)
BREAK FLUID: DOT-3
(fill to the level)
I have possi/trac loc in 03 liberty,I add 7oz of possi additive. Thanks for all info though!
1ino
I have been using Delo truck antifreeze for years without any issues including on my Prius with 450k miles
It as a lifespan of 500k
