ThunderbirdJunkie
Bronze Supporter
Holy crap!
you only have like 1.5 inches of travel.
Wrong rear coils...100%...
Here's mine.
I showed my Tech this picture and he said that the Rear Spring is supposed to be this way.. When you put a Longer Spring on the Jeep, if is going to kick back the Control arm and be a little curved.. He said that you could try to locate a Longer Control arm.. But he said that it really isn’t necessary for a 2” Lift Kit, and you would be fine with the spring looking this way..
Dear friends, thank you for for your effort and help. Unfortunately, mechanics here(who claim to be experienced on Chrysler Jeep), do not have as much theoric knowledge about lift kits EVEN as me.. Despite this fact, they love to charge people shocking amonts, as well as doing a 2 hrs work in 2 days..
I'd love to take care of it myself as Tony said, but I haven't taken out a single bolt from a car in my life, nor do I have the tools to do it.
BTW, I have no other complications with the new suspensions: The ride is superior, stability at high speeds, sudden brakes and sharp turns are cool. No jumpy or stiff ride..I love it.
The only problem is the disturbing THUMPS, which comes also from the front of the vehicle (I realized today).
Here's an illustration I now made to explain how it happens. 1) When dropping down an incilination to a flat surface, 2) When colliding with an inclination:
Talk about OME 948 rear springs, here they are, which exactly look like mine. Long and 8 coils spring, not short and 4 coils like yours. If BDS coils are ******, how different could the same shaped OME coils possibly be at full flex??
http://jeepinbyal.com/prod-OME_Spring_for_Rear-625.aspx
Both 947 and 948 have the same pics. Even if we assume they are not OME, they may be another brand, also both Skyjacker and Rusty's have the same type of rear coils for the KJ. Plus, after examining the photos of my rear springs, the technician's statement at 4wd.com is above.
Given all these, it's hard for me to believe the coils belong to another vehicle. Still if they do, I must admit they are really good substitutes for the KJ
Anyway, back to the main problem: The thumping noise.
Sounds like it's the bumpstops hitting each other.. If my rear coils are more likely to stack up at hard bumps, I theorically need longer bumpstops to prevent this. As Tom said, I have about 2" of lift. If I cut 1/2" off each bumpstop, the springs will compress more. Will I have more stacking issues at the cost of getting less thumps? Or should I cut them off right away?
are the crush sleeves in the rear shocks the correct size? (take out the bolts, see if they are the same size as the inner diameter of the steel tubes in the shocks)...
Upper crush sleeve not the same whith as the pocket? (Resistance, check if you can move the top end of the rear shock sideways)
