Reverse
Ericafisher01
2007 auto jeep liberty 3.7 does not back up when in reverse. All of the gears work fine but when in reverse it does not move when trying to accelerate. We tried changing the transmission fluid and filter and it did not get any better
blackhawk
Venezuela
I have this same problem but only when you want to back up in a slope. Try to use your 4x4 if you have it
jamesw
i have exactly that after new box fitted into 2.8crd. reverse should work in limp mode but i have not figured out how to put the car in limp mode yet any ideas?
Is it a new box or a second hand one?
Not sure if just unplugging it would do it, it would be purely in mechanical mode then.
Deb'nKJ
One of my XJ's developed that fault: it will only reverse in low, on the level & with the wheels straight ahead - but if I get out & lean against the B-pillar it will go faster than in neutral. Go figure. Time was when you could get an XJ for the cost of having a trans repaired - & I suspect KJ's are in that position now.
Different trans, very similar issue - so will be following this with interest, as have no idea what the problem is, much less the fix.
Jeremy-WI
Home
Remove the fuse that powers the transmission
