boebr1
Is anyone running the RRO UCA's? I noticed they are about $100 cheaper, look slightly different but seem to have the similar specs. Wondering if anyone has had or has heard of problems with them.
I did do a search, but didn't come up with a comparison of the parts...is our search function broken? we should put this in a top 100 Frequently Asked Questions thread
The thing I wonder about the JBA arms is, why does he have to keep upgrading them? As in... what changes between the different generations?
I ordered the RRO UCA and started my install only to find that once the arms are installed you cannot grease the handy zerks installed on the upper control arm bushings. The zerks sit to far into the pocket the arms attatch to. Also the boot on the ball joint does not reach the steering knuckle and i think that any grease injected at the zerk will just "run" out of the boot. I have an email in to customer service and will see how they resolve these issues. I plan on retunring my RRO arms and buying JBA arms. I will post again after dealing with RRO.
YesHow much lift will I need to install the JBA UCAs? I put on on OME suspension last year. Will these fit?
DJ
That is a bunch of horses**t.There is no tool to "punchout" the LCA mounts holes as they are already slotted.The tool they will try and sell you is made for older IFS GM fullsizes and that is to knockout the slots for there UCA's.Funny thing is the UCA's bolts GM uses are M12's and the LCA bolts on a KJ are M16's so that tool would be worthless and way to small.I have the RRO arms and I say dont waste your money... they rubbed bad on the sidewall of the tire the grease zerks are at an angle to where I cant grease em, and they are too wide, and its no where near close to alignable... I called em and they said I had to rent their tool to punch out the hole to allow more adjustability on the LCA, but Id have to re weld the little adjustment collar for the lower cam bolts. RRO customer support was no help at all
