theblueliberty
i've been raving about this stuff ever since a freind of mine recommended it and i replaced it with the usual cheveron mineral oil. this stuff is kinda expensive. about $7 a quart, plus an oil filter comes out to around $45. but this stuff is just sooo amazing! i may not be getting much horsepower out of it, but i recently installed a lift kit and big tires and my gas milage shot through the floor. i needed an oil change though and started using this sythetic oil and i get the same gas milage i did back when i was all stock!!! the best part about this stuff, is that the oil is actually purple!!!! haha, amazing!
Royal Purple Synthetic Oil - about $7 a quart
does improve some very minor performance but signifigant to gas milage (at least in my situation).
Can be found at your favorite local auto parts store such as: Shuck's, Pep Boys, Parts Plus, NAPA Auto parts, or whatever you happen to have in your area.
RATING: 9.5
WARNING: once you switch to synthetic oils, you can never return to mineral (aka regular) oil! doing so could cause catestrophic damage to your engine! so if you switch, be prepared to spend a pretty penny on your oil changes from then on.
RATING: 9.5
