rustys off road lift
gsambray
thunder bay
I am looking at buying the rustys off road 2.5 inch spacer lift for my 07 liberty. Its a daily driver and some light off roading. Are they any good. Looking for budget as i am not using this as a wheeler that much.
You will be alot happier if you spend a little more and do it right the 1st time.The ride difference by using actual lift coils and new shocks is worth it,also the added safety factor also.Your kidneys and back will thatnk you.
OME is best but ironman is right there also.
gsambray
thunder bay
Im gonna take your advice and apparently everyones advice online. Im gonna slowly put together my own lift. Either ome or ironman springs and not sure about front sruts and rear shocks. Ive heard rancho is ok but not sure if i can go as pricey as bilstein. That way i can by pieces at a time when i can afford and have a good no spacer lift.
TwoBobsKJ
Northern Ohio
That's a smart decision right there :happy107:
gsambray
thunder bay
Ive searched all over and cannot find a pic of the rancho that shows that it takes a clevis on the bottom. Maybe the bilstein is the right choice since it actualy shows what part your gonna order. Its just me sure but i would like to see what i am ordering not just a general pic.
Look at the Ironman as well
they are a bit longer have a larger diameter rod than stock or Bilstein as well
