service schedule
offrovering
oh
does anyone have a copy of the service schedules for these things? i have a 2003 and need to figure out what needs to be done. i dont have the manual near, was hoping someone could help me out.
Thanks!
offrovering
oh
How many miles does it have and what have you done thus far?
almost 90k
I have done all scheduled maintenance according to the schedule since new. i took ownership around 60k, but up till 60k it had all scheduled maintenance. at 72 I had a maintenance i thought??
i think 90k is ****** fluid, plugs?
_UnLiMiTeD_
B.C Canada
engine oil, check pcv valve, check the air filter, inspect drive belts, and inspect tranfer case fluid
I drop and replace the filter and oil in the ****** every 30k but I dont believe my OM calls for it till 60k.
It calls for the spark plugs and transfer case every 30k and the front and rear diffs every 15k. Although I personally believe if you change the diffs at 15k to get the break in metals out and off the magnet and do not offroad or tow much, then it should be ok to do those every 30k.
Wouldnt be a bad idea to go ahead and drain the antifreeze and replace that along with the radiator hoses, t-stat, and engine belt. Ill probably do all of that at 60k. Ill probably do the power steering fluid at 30k and 60k also.
Ohh, and dont ask tjkj what he thinks about all of that, he changes all of that every 10k miles.:p:D
_UnLiMiTeD_
B.C Canada
the transfer case is only to be inspected at 30k and done at 60k according to the manual.
It doesnt take 10sec to do and I dont believe 30k at all(even though it says that). Mine was brown when I drained it and it should be red.
Also, one of these makes it ALOT easier to refill the tcase and the diffs.
I picked it up at walmart for $8 or so and its worth it!
JJsKJ
Lancaster, Ca.
Kinda OT but since jeepjeepster mentioned it...
When you change your belts and hoses, if they are still working ok, save them as spares. I keep my old extra set in my off road bag that goes on trips w/ me just in case I or another KJ breaks a belt of springs a leak in a hose.
I had to use the spare lower hose in my XJ once to fix someone elses rig. Sure comes in handy.
Ken
West Virginia
Now does one need to change the differential lubricants that often is one does not go Off Road with the vehicle. These change periods seem awfully short to me every 30,000 miles .
But what the Hell do I know....
JJsKJ
Lancaster, Ca.
I would change out the factory stuff that early or earlier but if you use a good quality full synthetic gear oil at that change then you could easily go up to another 100K before changing as long as you don't wheel in water or tow often. Regardless, you shouuld keep an eye on the level and to look for obvious signs of contamination.
offrovering
oh
****** fluid turns brown after use, doesnt necessarily mean the fluid is bad. ATF fluid is made red to distinguish itself from other fluids, but does not stay red, just FYI
I cant figure out how to cut just a section of the PDF from the FSM or I would have posted the schedule. After asking I ended up getting the information, thanks
