Jeepkj
how hard is it do complete a SFA swap this is my only means of transportation so how long would it take? is there a place where i can get everything i need like in one order?
Try being the test dumby.Like stated not a weekend project.sounds like alot of fun
Nothing against the JBA kits, Marlin makes great stuff. Just wanted to compare apples to apples. Sure, the SFA kit isn't cheap if you skip the parts list and just look at the price, but to shed some light on what you get for your dollar, it is all top quality parts, just like you would have to do to the JBA 6" kit, and I didn't add all the top of the line parts to that shopping cart. Install time won't be much different between the two either.
Anyways, have fun. I did. :icon_twisted:
Marty, is there any way to do an SFA with only 6" of lift?? I would prefer SFA over JBA IFS, but if I must have 10-12" of lift there is no way I can do a SFA... :shrug:
Thanks Marty, which part of the axle would be close to the oil pan? The upper control arm brackets over the diff?? I remember Troy said a long time ago about working with some old ford radius arms to avoid upper control arms... Do you think it would work??
How much does the phase III kit weigth?? Do you plan to make international shipments???
Thanks
I don't remember what it was that was close to hitting when we lowered it to 6". I'll have to check with Troy.
