Side Marker
5characters
SE Ohio
The reflective side markers on the front bumper how does one go about removing them?
Do I need to pop off the clips on the wheel well lining to access the marker? I only looked for a second and wasn’t able to get underneath the Lib, so this topic may just be in vain. But if there is some mystic process I need to follow, could you point me in the right direction.
Also is the only thing holding the lens for the turn indicator the screw by the grill?
The screw on the far left (right for the other lens) for the turn indicator.
5characters
SE Ohio
Thank you
That’s good news, I think the marker will pop off, i just have to find a way to access it, if only I had a real garage, I’d be in there figuring this out instead of sitting around waiting for it to clear up outside.
ChiefRudy
Pittston, Pa
Unless the lens is broken, why do you need to remove it? If you need to access the bulb to side marker just stick your hand up into the bumper . Then twist and pull.
You you really need to take it out..
you might be able to find the clips that hold it in while sticking your hand up there.
5characters
SE Ohio
Nightshading them, the jeep is silver with the black accent, I think having the side marker and turn indicator blacked out would look good. Not ridiculously dark just enough to make it flow together.
Something like this (not my jeep but same color combo)
Elmer
Delmarva
I used niteshade on mine but just masked them off. Pretty easy job, nice straight lines.
