Searcher67
I called to order my transfer skid plate and was told NO LONGER AVAILABLE!
Now I have to fabricate my own!!!
The skid for the '05+ models can be made to fit, it's just that the mounting holes don't line up perfectly. You can overcome this by either drilling new holes in the skid to match the mounting locations you have, or just drill thru the crossmembers and run bolts all the way thru (but don't drill thru a panFrom where??? I think an 03-07 would also fit....
And if you can't by new, consider a used one...
The skid for the '05+ models can be made to fit, it's just that the mounting holes don't line up perfectly. You can overcome this by either drilling new holes in the skid to match the mounting locations you have, or just drill thru the crossmembers and run bolts all the way thru (but don't drill thru a pan).
