Se7enLC
Q: What Skidplates do I need?
A: If you want to have a full set of skid plates, here are the plates you will need:
Q: What Skidplates do I already have?
A: Depends on what model you have. Best way to find out is to stick your head under there, but here are some guidelines:
Q: I have a 2002-2004, how do I get a transmission skid?
A: You should be able to use a 2005+ transmission skid plate with minor modifications. Information on the modifications needed can be found here:
http://www.lostkjs.com/forum/phpBB2/viewtopic.php?t=6021&start=60
Q: What are the part numbers for Mopar Skid plates?
A: Here is a list of available skid plates, and their part numbers
Q: What hardware do I need to install skid plates?
Your kit should have come with the hardware, but here are some part numbers:
Q: What tools will I need?
A: You will need the following tools:
Information for this FAQ was found in the following LOST forum thread:
- Front Suspension / Engine skid
- Transmission skid*
- Transfer case skid
- Gas Tank skid
- If you have a 2005+ Liberty with the offroad package, you have all 4 skidplates
- If you have a 2002-2004 Liberty with the offroad package, you have the Front Suspension/Engine skid, the Transfer Case Skid, and the Gas Tank Skid
- If you have a CRD, you have the Front Suspension/Engine Skid (but it is a thinner skid than the normal Front Suspension/Engine Skid included in the offroad package)
- Engine/Suspension (2002-2006) - #L82209026
- Engine/Suspension (2002-2006, old part number) - #52128925AC
- Transmission (2005-2006) - #L82210003
- Transfer Case (2004-2006) - #L82209455
- Fuel Tank (2002-2006) - #L82206122
- Rivets - #6506644AA
- Screws - #65060227AA
- 18mm Socket + Breaker Bar or 18mm Wrench
- Tool list is incomplete
