Mechanic may be correct. The NGK's should come already gapped at .040
Still worth checking though.
I used the NGK's and they were gapped at .040 but I always check anyway so I was sure they were right when I put them in.
Excellent that you checked the gap! Might want to tell the dealer what you found...I checked the plugs that the dealer installed during the tune-up. I too thought NKGs came gapped at .040. Even though this is the case, I have always been in the habit of checking the gap when I install. If the technician had been in the same habit, he would have realized that these NKGs were gapped at .030. I re-gapped the plugs to .040. Jeep is running much smoother now. I feel better that I know for sure the gap setting. I, also, checked the throttle body. Not a lot of carbon. I think the gap setting resolved the rough idle.
Now find a bottle of Chevron Tecron and take it for a good highway boogie!!
I always check the gap on each new plug before install too, some are out a bit.
I called the Chrysler dealer today and asked them about the spark plug gap for the NGK
Platinum plugs I bought...
(According to the instructions on the NGK plug carton, it says not to regap the plugs!)
The mechanic I spoke to at Chrysler said to just install them without re-gapping them!
some beleive that gapping PLATINUM plugs will ruin them and cause them to wear faster. i check em anyhoo ....have yet to find one that was significantly off spec.
