Standard flooded or AGM?
mike
Colorado Springs, CO
2007 Liberty, a little less than 73000 miles. 3.7, auto. Currently has a 6 year old Super Start Extreme (part no. 34EXTJ) standard flooded battery. No obvious battery issues, I want to replace the battery because of it's age. This is my wife's car, it's driven less than 1500 miles a year. Mayhaps less than a thousand. I'm wondering if I should get an AGM battery? The Super Start Extreme has been real good, and I often (weekly or more) leave a Noco charger/maintainer on it at least overnight, sometimes for a few days. My question is, should I replace the battery with an AGM or get another Super Start Extreme?
Thanks, Mike
I stopped buying lead acid batteries many years ago. AGM's tend to provide greater cranking power, especially when it's below freezing.
You won't see corroded terminals on AGM's either.
u2slow
BC
I'm recently onto the second AGM in the jeep. Pro-actively replaced at 7yrs. Keep it as a shop battery till the end.
Luke
Interloper
Bancroft, Canada
AGM FTW! … just be aware that they like to receive more volts for proper charging, raising the voltage to ~14v will extend the life of your battery.
mike
I'm not sure what all this means, Luke. You say they like to receive more volts. Does this mean that if I switch to AGM I'll also need to change the alternator? I have a Noco Genius 5 tha I use regularly. If I change to AGM will I want to use it from day one?
