Standard flooded or AGM?
mike
Colorado Springs, CO
2007 Liberty, a little less than 73000 miles. 3.7, auto. Currently has a 6 year old Super Start Extreme (part no. 34EXTJ) standard flooded battery. No obvious battery issues, I want to replace the battery because of it's age. This is my wife's car, it's driven less than 1500 miles a year. Mayhaps less than a thousand. I'm wondering if I should get an AGM battery? The Super Start Extreme has been real good, and I often (weekly or more) leave a Noco charger/maintainer on it at least overnight, sometimes for a few days. My question is, should I replace the battery with an AGM or get another Super Start Extreme?
Thanks, Mike
I stopped buying lead acid batteries many years ago. AGM's tend to provide greater cranking power, especially when it's below freezing.
You won't see corroded terminals on AGM's either.
u2slow
BC
I'm recently onto the second AGM in the jeep. Pro-actively replaced at 7yrs. Keep it as a shop battery till the end.
Luke
Interloper
Bancroft, Canada
AGM FTW! … just be aware that they like to receive more volts for proper charging, raising the voltage to ~14v will extend the life of your battery.
mike
I'm not sure what all this means, Luke. You say they like to receive more volts. Does this mean that if I switch to AGM I'll also need to change the alternator? I have a Noco Genius 5 tha I use regularly. If I change to AGM will I want to use it from day one?
I'm fairly sure the charging system on the KJ is controlled by the ECU so fooling it may be difficult.
mike
It seems that the product Luke mentioned is only for toyotas. I did a quick search for a similar product made for Jeeps. To be honest, most of what I read was way over my head. I did find an interesting comment on a Jeep Cherokee Club page, "One thing we can rely on is that AGMs sold for automotive use are designed to work with past and current automotive electrical systems." That's from 2 1/2 years ago. If this is true, that tells me that an AGM would be fine. All I want to do is replace the battery with one that will last. The Liberty gets driven rarely. This past week, it wasn't driven at all! This is more the rule, rather than the exception. I've had a Noco Genius 5 hooked to it for 2 days now. I'm just looking for the best battery to use in a vehicle that is rarely driven, < 1500 miles a year. If an AGM fits the bill, that's what I'll get. If it's best to keep using plain old batteries, I'll keep using them.
Any Group 34 will fit directly into the KJ. Of course the AGM is best.
The best AGM is an Odyssey Battery, but expensive. Odyssey uses virgin lead.
My Odyssey AGM is now close to 13 years old & still fires Jeep right up !!
If you buy the best, it won't die like the rest. :)
I've had a red top on mine for years, it's lasted well.
Luke
Interloper
Bancroft, Canada
It is yes… I also saw that post while searching for a Jeep solution. Without any reference to a source it’s difficult to assess it worth. You could check your alternators charging output with a decent voltmeter to get a baseline and then inquire with the battery manufacturer as to suggested charging voltage.
To be clear an AGM will be “fine” but if you want to keep it healthy for longer increased charging voltage is recommended.
As an aside you mentioned your short trips… this is another benefit to increased charging voltage, it handles that driving style better and you won’t need your Noco as much.
Luke
Interloper
Bancroft, Canada
Excerpt from the Odyssey AGM Technical Manual. Note the 14.2-14.5 volts. I could only achieve that with a voltage boost. It gets even more imperative as the temperature drops.
mike
Thanks to all. Lots of info to study. Thankfully it's not a need one now situation, I'm just planning ahead. My other car is a 2021 Ford Escape with the original (AGM) battery, it needs replaced soon. If I replace the Liberty battery first, mayhaps I won't be buying two batteries at once. Hopefully I can get a year between purchases.
How do I check this? You mention a voltmeter. I have a Fluke77 multimeter. Will that work?
A Fluke will do nicely, switch it to DC and measure the voltage at the battery terminals.
I'd guess you wouldn't see much more than a fluttering 13.5v as the ECU runs as an AVR on our setup.
As I said earlier, I've had a redtop on my CRD for years and it's been excellent, the specs for charging it are a bit lower than the Odyssey at 13.3v so it's probably more suitable for a Jeep.
