Starts, stumbles, and dies when warm
CherokeeLiberty
Northern MN
This has been an ongoing issue, but I almost missed my dog’s vet appointment because of it, yesterday.
Sometimes when I’ve been doing errands, I’ll hop in to head out, and the engine fires, stumbles, and dies. Sometimes, I can save it by mashing the gas pedal, sometimes not. Any ideas on what to check?
How many miles on the KJ now?
Fuel Pressure test it..Compression test as well ? Recent tune up? New plugs ? IAC clean or replaced?
CherokeeLiberty
Northern MN
Just over 203k miles. I’ve never done a compression test, and I have not cleaned the IAC. Spark plugs were replaced 30k miles ago.
30k miles is about where I would consider new spark plugs. Coil packs fire very hot, and gaps can get eaten away.
Have you ever replaced the coil packs?
Use NGK spark plugs:
Check gaps & take photos of plug conditions !
CherokeeLiberty
Northern MN
Apparently the ‘07’s don’t have an IAC? I cleaned the TB, and it wasn’t terrible. The MAF is dirty, and I don’t have cleaner for it.
Spark plugs were eaten up, a bit. The gaps were all between .044” and .054”. The parts store is closed today, so I closed the gaps to .040”.
oh u have an 07, so no IAC.
The ignition fires the plugs hot & best to replace them every 25k miles due to gaps out of spec. Plugs do look correct temp, no fouling.
Is it running ok now ?
blackhawk
Venezuela
Check the wiring.... One is a positive common for all the coils and a pulsed negative
