Gwakie
Hi Folks, All my stop lights just stopped working. I already checked the fuse box and all was in order. Any ideas? Alos how do I replace the rear bulbs I cant seem to find the access panel.
Check the bulbs...make sure they are not blown. Do do this, open your tailgate and get out a torx set. Undo the two screws that hold the light in and pull out (Takes a fair amount of force to pop them out...more than you would think)...just pull straight out towards you. Then twist the little caps and pull out to check the bulbs. Hope it helps!
-Ryan
You're sure it's not a fuse? Hmm, the only other thing I could think of would be some sort of relay, but I don't have my manual handy so I'm not sure if there is a relay for the stop-lights. Oh, and by 'stop lights' I assume you're referring to your brake lights?
