subs with stock deck
bfaas
Pittsfield, MA
is anyone here running subs (none in particular) with the stock cd player?
if so, how's the quality?
I am,pretty good gives alot more bass to the factory system.I had no use for anything more than what the stock CD player did so I kept it.You need that little dohicky(don't know what it called but it cuts down the power in the factory wires going into the amp to prevent it from frying) to hook up a amp to the factory system.I run 2 10" EarthQuake Depth Charge subs and a Lighting Audio 750watt amp.
