Did i get the wrong regulator
04Roadglide
2004 liberty. My right rear dropped by itself overnight. I shopped around and decided on Rockauto.com. The regulator I picked claims it has a limited lifetime warranty. The picture on the website showed what I think is a new style? What arrived is exactly what I removed and has a long history of failure.
I couldn't find any way to contact Rockauto and ask if there had been a mistake.
I went ahead and installed out of frustration!
Would someone know if there actually is a new style using the same part number
Thank you Chris
seafish
post deleted….I have NO idea why I though you were talking about the rear lower control arm. :oops:
DadOSix
Cumberland, MD.
Front regulator:
Has a wide nylon clip
Rear Regulator:
Has a narrow nylon clip to hold the window.
I can’t make my picture paste over on the ipad.
Maybe you can post the part number from Rockauto?
04Roadglide
Posting pictures of what Rockauto showed, which is not what I got. The one I received is identical to the one I removed
The label shows the part number
DadOSix
Cumberland, MD.
So, what you took off is the OEM style. The 660545 picture is a new version - what is important is the white nylon clip. It should look the same (more or less) as to what you took off.
When these break one of a few things happen :
1 - motor locks up - rare
2 - cable binds in the track and will rip itself out of the white nylon clip. The unit APPEARS to be unfixable, but I found the clips on Amazon or ebay and have a complete set (or 3) in my toolbox.
3 - white tubing that carries the cable cracks in one or more places. I think this stuff is like PVC waterline, but have never found an exact size that will repair the tubing. I have tried with some success to go a larger diameter, cut a few inches on bigger tube (3-4) and split it lengthwise. Then it'll slip over the break. model glue, pvc cement, hose clamps, etc. have been used with some success until I can find another unit.
4 - the window will sometimes 'pop' out of the clip - (this is the sudden fall symptom on mine) The stud pops out and the glass flies down into the door. There should have been a 'hairpin' style metal clip that goes thru the white clip and holds the stud in place.
Good repairs!
04Roadglide
Good repairs!
Good repairs!
Thank you for the reply. So I'm very disappointed in Rockauto for sending a product not the same as what's pictured. The part number on the label was also stamped into the track of the new part. So I guess you get whatever they have in stock under that part number. I chose the one pictured because it says it has a lifetime limited warranty. I'm assuming that would just be empty words should the new one fail.
This was a fairly easy repair with the exception of trying to get the post on the window through that white plastic piece. I finally grabbed some channel locks and squeezed it all together. I think that the metal clipped seated in place. Probably would have been a 30-40 minute job if not for that hassle
DadOSix
Cumberland, MD.
Future reference - pull the hair pin. Slip the stud into the plastic and then slide the hairpin back in place.
04Roadglide
Yes, that's what I did. I think the stud was slightly bent up. I've since read that I should have straighted that. Thank you.
DadOSix
Cumberland, MD.
So - if it works a few times and then binds at the top, it may pop off again. Not a bad regulator, but now you know where and what to look for.
Dave_too
I think you're better off with a regulator from Steiger Performance, myself. I've had all four windows go as well as their plastic replacements. This is a known issue which I think was a recall at one point, though I won't swear to that. Used Steiger on all four windows in 2010. No problems since.
Dave_too
in the meantime, I kept the windows up with an old school wooden door stop (wedge-shaped) between the bottom of the window and the inside door. Effective and much cleaner than tape.
Dave_too
It wasn't a recall per se, but Chrysler agreed to reimburse for the cost of the repairs. There was a timer on the offer that expired years ago.
