After more than a year of fannying about, it really is time to do something about the KJ's suspension. It's like driving a space hopper right now
I'm not doing a lift as I cannot justify it so this is all bog standard.
So things I think may be wrong:-
1) Shocks pretty much for sure - I plan to fit Bilstein H6's all round.
2) I think the upper rear control arm (boomerang) may be on the way out. The rear of the vehicle seems to feel loose and it apparently a weak point ?
3) Upper front swinging arms - the inboard bushes look very perished.
So I am looking for advice on the difficulty of doing each of these jobs and other jobs I should consider including along the way:-
1) The rear shocks look easy enough but the front not so. Is a special spring compressor needed or will standard screw types fit ?? Is it likely the springs need changing as well - how do I check them ? (the Jeep has done 116K). Are the front strut mounts likely to need changing ?
2)The Upper rear control arm looks ...... interesting. A youtube video recommends also changing the ball joint on the top of the diff ? What controls the droop of the rear axle - I am guessing I will need to support it on axle stands ? What else will need to come off to allow the arm to be extracted ?
3) How do you access the inbord bolts on the upper front arms and are they likely to need replacing ?
Any and all advice welcome - this will be the biggest job I have tackled in years.
