Isn't synthetic oil really just recycled motor oils?
That in turned have been chemically engineered back into a "Synthetic Oil"?
I hope you are joking.
Those are?There are dangers to using Synthetic oils, especially in older push-rod/roller lifter engines, and old leaded gas engines.
Those are?
Older pushrod engines with Roller Lifters; The roller may not spin with camshaft movement, but rather slide while the roller remains either stationary or at lower circumferential speeds than the camshaft lobe.
Synthetics do not hold lead in suspension as well as DINO oil, so they advise caution when the engine is run on leaded fuel.
I hope you are joking.![]()
No, I've got proof. One time, I dropped my oil drain plug in the waste oil pan, couldn't find it, and dumped it in with the waste oil to be recycled. A few months later, I bought some synthetic oil, and started to change my oil. As I was dumping one bottle in the funnel, out comes my drain plug! Good thing my funnel has one of those little screens in it. :^o
